Two wired extractor fan connecting to three wired old fan
13 Jul 2021
Hi!
I am removing the old extractor fan in my bathroom - the old has three wires - live, switched live, and permanent live. It is hooked up to the fan isolator.
my new fan only has two wire inputs. Permanent live and neutral.
can I use my new fan with two of the three wires which went into the old fan? And then wrap up on unused wire in electrical tape?
I purchased the two wire fan by accident.
thank you!
You mean - Neutral, Switched Live and Permanent Live.
No, it has Switched Live and Neutral.
Yes, wrap the Permanent Live - but it would be better put in a separate connector block.
You can nick a connector block from the old fan to put the spare permanent live wire in.
Your room, from its construction, may require a fan with an over run timer. Does it have any form if ventilation, an opening window perhaps?
Better to return the wrong fan and use a timer fan.
