We had the lead mains replaced today by a contractor for Thames water. He put in 25mm id blue PVC pipe - tariffic flow now.
But he kept getting leaks on the plastic fittings he used - they had an o ring inside the fitting. He put a nut on the pipe, then a plastci "gripper" ring, pushed the pipe into the fitting and tightened the nut so the ring gripped the pipe. I assume the O ring inside the fitting did the sealing but at least two joints kept leaking. It took several goes to get it right.
Is there a better system ? This seemed like a push fit system that couldn't cope with scratches on the pipe.
