- Joined
- 11 Jan 2004
- Messages
- 46,759
- Reaction score
- 3,939
- Country
No, they're moonatics...If those from Mars are Martians, are those from the moon, lunartics?
You are forgetting about a UFOs capability
"There's us lot...
...and God."
I think this is why they are best left alone with their fantasies. A gram of intelligence is wasted here.And since your definition of what a UFO can do is 'anything' that gets you out of trying to explain anything
Wrong lens flare does not appear from behind another object - starship you must either be not looking at the vid or you are looking on a small device as the ship turns it slowly becomes visible it is clearly an object behind the starship. You have ruled out a separation plume so only a real physical object option remainsHardly, because it's a lens flare, which you haven't even tried to disprove. It behaves exactly as you'd expect one to do so.
You are just being argumentative for the sake of it - orbit - hover - actually if I wanted to be as argumentative as you then I could argue that things dont hover in space.And since your definition of what a UFO can do is 'anything' that gets you out of trying to explain anything that we see, you just shout magic and run off in a huff.
Just don't use terms like Orbit instead of hover, because you make yourself look ignorant when you do.
You would say that as you always side with your lefty mates......can't you think for yourself?I’d say it’s lens flare. Seems like a sensible explanation.
I can say categorically it’s not space aliens.can't you think for yourself?
But, what proof have you that's it's not NHI?I can say categorically it’s not space aliens.
The fact that aveatry can’t identify it, says more about him than the ‘object’.
I’m sure the boys and girls at NASA or those monitoring the launch, would have Whatsapped aveatry by now, if it had been anything sinister.But, what proof have you that's it's not NHI?
Of course it can appear that way. As a light source (clouds) move onto frame they reflect light and in this case cause a second source of lens flare.Wrong lens flare does not appear from behind another object
Even though you haven't a clue what lens flare is.I’d say it’s lens flare. Seems like a sensible explanation.
Funny isn’t it all noseits posts were just mocking - nothing to add to the conversation - not thoughts of his own to what it could be and then as soon as I said "no one else thinks its a lens flare" to minions post - up he pops saying he thinks it is lens flare.Even though you haven't a clue what lens flare is.
