No reason why a competent DIYer should not sign the design and installation boxes in the EIC, leaving a registered electrcian to do the testing and to sign the appropriate box. It has to be notified though unless all the signatories are registered.Maybe, then, some of those here will have to modify some of the responses they give. It seems quite common for a poster to say that he's going to replace a CU (or whatever) 'and then get an electrician to test and certify it', and commonly will get at least one reply along the lines of "that's not how it works" or "you cannot do it that way" - but, in view of the above, maybe they might need to re-think their answers a little?
In the case of this thread the registered electrician can sign all the boxes because he's installed the CU, so notification is not required.
I can't see why any rethink is needed.
