Under cutting skirtings
1 Mar 2017
I like the look where your tiles slide under the skirting rather than kind of butting up against.
So probably easier when there's no skirting so you just stick it on after your tiling. But I've seen a few you tube videos where they've under cut the bottom of door frames by using an upturned tile as the guide.
I'd like to do something like this but for the whole skirting. Do tilers generally do this?
I'm not opposed to pulling the skirting off, its just we have one room where we have magnetic plaster (which is great) but soft compared to normal plaster and taking the skirting off in that particular room might prove to become a nightmare, hence the under cutting option.
Butt your tile up 4mm shy of the skirting - you leave the 4mm gap to be filled with silicone.
Colour match the silicone to the grout colour.
You can use grout right up to the skirting board, as well as silicone, but by the time you've put down the tiles and adhesive, the skirting board might start to look a little short. As long as you are careful taking the skirting boards off, then when they go back on, the should cover over the damage to the plaster.
Best modern practice is to silicone where tile meets any abutments - for the simple reason that its insurance against expansion.
If at all possible, on the principle of keeping things simple, skirting is best left on the walls & undercutting is avoided - why create more possible difficulties?
