commercial links removed
I'm undergoing a renovation project and looking at installing some underfloor heating.
It is a lower ground floor flat with a concrete slab for a floor. It's approx 50sqm and consists of a open plan kitchen/living room and a large bedroom.
The current central heating system pipes are copper and set into the concrete slab. They were installed in the late 80s so i'm terrified that at some point they will leak and i'll have to take up the flooring i'm about to install, and then dig up the slab to fix it which would be costly and intrusive.
As a work around I have been looking at installing UFH on top of the slab and underneath an engineered hard wood floor. This way I could completely remove the old radiators and heating system, eliminating the possibility of it failing. I am also looking at putting a membrane between the slab and the UFH due to damp issues in the flat.
Does anyone know if this system will be powerful enough to heat the entire flat without the need for radiators?
Will there be any issues installing the UFH on top of the Oldroyd membrane?
Is there anything else I should be considering here?
