underfloor squirrels.
Discussion in 'Plumbing and Central Heating' started by Axel, 12 May 2011.
  1. Axel
    Axel
    21 Sep 2008
    993
    Thanks Received:
    78
    London
    Country:
    Met a pest control bloke today who reckoned that squirrels gnaw through Polypipe / Hep etc.
    Is this something that we in the plumbing industry should be worried about?
  2. Sponsored Links
  3. hansthebear
    hansthebear
    24 Mar 2011
    603
    Thanks Received:
    69
    Edinburgh
    Country:
  4. xr4x4
    xr4x4
    1 Oct 2009
    3,159
    Thanks Received:
    290
    Hampshire
    Country:
    And rats don't?
  5. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    only if you use it on gas ;)
  6. Axel
    Axel
    21 Sep 2008
    993
    Thanks Received:
    78
    London
    Country:
    Are you trying to gas the squirrels?
    Have tried to solder onto polypipe - it works a bit and you don't need any solder, the pipe melts onto the fitting. Probably best do this only for a gas line as the presure is lower.
  7. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    only the grey ones
    good point, hadn't thought about the low pressure making it a lot safer :oops: ;)
  8. mickyg
    mickyg
    24 Aug 2005
    16,007
    Thanks Received:
    3,325
    Cornwall
    Country:
    i've replaced some chewed pipe under park homes, but very rare, and on those its easily accessible to all rodent life lots of plastic pipe for them to feast on, so I dont think its a big issue. I wasn't however there at the time of the incident taking place to identify said rodents !
  9. nickso
    nickso
    30 Oct 2006
    6,722
    Thanks Received:
    302
    Country:
    i replace a reasonable amount of chewed plastic. housing estates in the middle of fields with plastic pipe, not a great idea.
  10. Sponsored Links
  11. rojaca
    rojaca
    14 Dec 2008
    744
    Thanks Received:
    80
    Country:
    smear peanut butter on the electric cables will stop them way before they start on the pipes
  12. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    :LOL: :LOL: :LOL:
  13. adlplumbing
    adlplumbing
    9 Dec 2009
    6,341
    Thanks Received:
    998
    Lancashire
    Country:
    how about being propper plumber and replacing it with copper :p
  14. numpty1
    numpty1
    30 Nov 2007
    3,569
    Thanks Received:
    839
    Country:
    too expensive :LOL: peanut butter on the cables i like that :LOL: :LOL:
  15. Garfeild
    Garfeild
    19 Jan 2007
    1,283
    Thanks Received:
    171
    Kent
    Country:
    I worked on a house in Wimbledon that had the top floor burned because of squirrels chewing through electric cables,apparently they are attracted by the "sound" of the current going through the cables,so dont need peanut butter smeared on them.
    It might be better to put the butter on the plastic pipes,so the house gets wet but without being burnt first?
  16. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    You could argue that the house caught fire due to dangerous wiring. If it had been wired properly, all that would have happened was a popped fuse/breaker.
    No such protection on water pipes.
  17. Onetap
    Onetap
    19 Jun 2006
    1,845
    Thanks Received:
    191
    Essex
    Country:
    Well done, you pathetic simpleton. I was reading this with kids in the room.
    You must still think that shouting out naughty words is funny. Grow up.
Loading...
Share This Page
