Got some lights to wire in a garden. Plan is to run an swa underground to each point and then use a flex up to each fitting, as the fittings will only accept flex and not swa.
Looking at 8 fittings so at some points an incoming and outgoing swa will be present , as well as the flex. It is desired to keep the junctions out of sight so bringing the swa's out of the ground into a local jb is not wanted.
Im sure ive seen some maintenance free junction boxes that can be buried and filled with a gel/resin, thus allolwing burial of swa and flex. Anyone come across such a beast or have i dreamt it?
Cheers
Cheers
