USB built into mains socket
1 Jan 2016
I'm thinking of purchasing one of these sockets but a bit worried how safe they are, I have been told that they are permanently on if so what are they pulling power wise ? Also they catch fire
They "pull" very little current, not enough to worry about. Some of the more expensive ones have shutters over the USB ports that disconnect the mains feed when they are not in use.
There is a very lengthy recent thread on this topic. Go to the search pane and type in "USB Socket". Its all in there and i cannot be bothered to wade through it all for you.
Really? where did you hear that?
There are lots of reports of plug-in USB chargers catching fire, but I did not hear of a combo socket flaming…
Stick with the decent brands from reputable sources, I wouldn't bother with a cheap one.
I recently saw a video on youtube where someone (Big Clive) took a cheap one to bits and found the earth connections weren't joined together and relied on you wiring them individually.
Buy MK Ones - they are made in Great Britain, as pointed out in the MK advert.
But even so they still have the problem that when the USB module fails the socket has to be replaced which requires competence in changing a socket. In the worse case the failure of the USB module could create an earth leakage fault which, if an RCD was fitted, would prevent that circuit being powered. Hence several sockets would be without power until the socket was replaced.
I have an MK one here with me. The unit would have to be well alight before it would be possible to cause an earth fault. An RCD tripping would be the least of your problems!
The MK USB charging Euro module is cheaper and easier to replace, and has the benefit of cutting the mains supply when the USB plugs are disconnected. They are made in Indonesia, just like most of the MK products are now.
I fitted an MK one for myself, don't think I'd have anything else. Have fitted a few BG ones, they seem ok
Is there no mains filtering on the input to the USB switch mode power unit ? No capacitors between Live and Earth and Neutral and Earth ? Not on a cheap item but on a better quality one there could be. A fault in the filter would create earth leakage,
How long till they go out of fashion and everyone is swapping them for mini or micro usb sockets? Now there's an idea........
The only mains filtering is with a common mode choke on the input in the MK ones. It is fitted with a proper Wickman type fuse though T:630mA
Unlikely in the short term. USB 3 is backwards compatible with USB 2 A type, so unless A LOT of manufacturers move over to USB-C type connectors, I can't see it happening any time soon.
