Hi
Basic (and probably stupid question) but I have a covered space between our back wall and what was the coal shed (now the bathroom) which shares a common wall with my neighbour - I have just pulled down the ceiling in this area (old sundealar type board) before it fell down and am looking to re-clad this area after applying some insulation.
The current roof is slate, which is in reasonable condition but has no roofing felt - as it was installed pre 1970. leaks managed with a bit of replacing and a little judicial mastic!!!
I do not want or can afford at this time to strip the roof and re tile as this would mean doing my neighbours half at the same time (makes sense).
before I place solid foam insulation between the rafters I want to fill the gaps on the walls - ridge, external wall etc. I would like to use expanding foam, but it seems all cans only work if turned upside down - which is impractical given the location
Any suggestions how to go about this?
Thanks in advance.
All comments welcome.
Dave
Thanks in advance.
Dave
