Hi all,
Wonder could someone help.
We have two toilets in our newly built house, both the smaller cistern/push button type.
One is constantly filling/overflowing (making small adjustments seem to stop it filling at all).
The other takes forever to fill for several reasons:
1. the water somehow is able to leak into the bowl as it tries to fill but once it eventually gets up to a certain level this stops????
2. the amount of fill water coming out isn't much to begin with.
3. It makes a deafening vibration/hum from (which i can stop by pushing down on the central flush mechanism - strange as i thought it would have been coming from the fill/water pipe.
Anyway, i'd like to have a go at trying to fix it or replacing it but i cannot see any isolation valve. Its almost like they've put the toilet in and sealed it up to look nice and neat.
My question is are toilets normally fed from the tank in the loft or the mains?
If its the mains is the isolation valve normally in some place (under the sink, outside under a manhole?)
If its the loft tank is there usually an isolation valve there?
thanks in advance everyone...
