Sorry for the late reply and if I was the cause of the thread being locked but thanks to the guys for the constructive replies. At least I can now get in touch with some fitters for quotes, knowing that what I would like is possible.
Can I ask why everybody seems to think that two boilers isn't a good idea ?
Not every one thinks it is a bad idea. The "professionals" on this forum may feel that way but then are they a truly representative cross section of the industry ?.
Every design of a combi has to be a compromise between high powered instant water heater and a much lower powered heat source for central heating. One function may operate at high efficiency but the other may function at a (much) lower efficiency.
That said bolers with variable geometry combustion chambers do operate efficiently at both functions but variable geometry chambers in a domestic boiler ? It will never happen. Far too expensive for the domestic market.
Sorry AGAS. With the other thread getting a bit heated, I didn't want to fuel the fire by replying until it'd cooled down a bit, hence the delay in me re-posting and I forgot you asked a question about water flow rate. Is this the "bucket test" ? If it is, I've just done one now with a three gallon builders bucket and it took 41 secs to fill it.
Can I ask why everybody seems to think that two boilers isn't a good idea ? I can't see why it would be but then again I ain't a gas fitter. I just thought that as long as whichever fitter ends up getting the job, as long as he gets paid there wouldn't be a problem.
As I said before, I just like the idea that if either goes faulty, I would only lose the water OR the C/H, not both. The main reason for posting on here was to see if it was possible as I had a lot of assistance from the guys on the electrical forum a few years ago. I wasn't trying to start an argument.
Thanks as always.
@muggles the op has a 30kw combi boiler and has repeated that he does not want an separate cylinder,
What complete rubbish!!! There's no compromise, 40KW Combi for HW output & a good turndown ratio for CH.
How is there no compromise? Do you design boilers? All boilers have a peak efficiency at a particular power point, just like every other device on the planet.
