Hello all,
Hope someone can help or suggest to me what I can do?
I've recently purchased a flat LCD TV - it's wireless - Sony KDL-EX1
The wall that I have in my house has lighting wires sticking out.
I want to use this lighting lead to power the LCD TV.
The LCD TV is 324 watts.
The lighting I tested has no switch - i.e. it is constantly on. I've tried all the switches in the house.
Only time it would switch off is when I tripped the lighting circuit.
I presume this was put there by the original owner of the house to put lights above the picture. He build it from new.
Is there a way that I could do this? Here is my intention - cut the plug from the LCD TV and then connect the wires to a small fuse box and then connect it to the lighting wires. Now all the wires are very neatly behind the LCD TV and hidden.
So the questions I have really are:
1: - Is this possible or would you say immediately not to do this?
2: - Where would I find a small FUSE box that I could put between the leads?
I do not want to knock a whole in the wall and put a fused socket there - because if we want to remove the LCD TV then I would like it back to where it is today.
Many thanks beforehand to your responses.
