COMMMON said:it replaced an old back boiler the 28 gravity flow and return was removed and the existing heating circuit was used and join to the boiler in 22mm i can be 100 percent that there is no dumbell valve ive noticed that the f&r heats up fine as it runs across the landing and is new pipe work but just wont flow down drops or to most of the rads ill try tommorrow shutting all rads and opening the 1 drop to see if i can get heat ,it just sounds like theres not enough flow running around the circuit
