    Dismiss Notice
vaillant ecotec plus 832 overspec
Discussion in 'Plumbing and Central Heating' started by GRhodie, 1 Sep 2020.
  1. GRhodie
    GRhodie
    20 Nov 2018
    9
    Thanks Received:
    Country:
    hi, i was advised to put an 832 boiler in my bungalow, 18 months ago. i have fitted the vsmart controller but the rads are on or off never warm as i understood it would work. i have been reading lots of posts - could my boiler be too powerful? i have 8 radiators, if possible can i reduce the power output?
  2. Sponsored Links
  3. picasso
    picasso
    8 Apr 2008
    10,211
    Thanks Received:
    2,498
    Essex
    Country:
    Your boiler has a maximum of 24 kw to the heating and automatically modulates to the heating load, the 32kw is needed for hot water generation, if your rads are running hot you should speak to the installer about adjusting the heat curve( if it’s possible with the vsmart)
  4. GRhodie
    GRhodie
    20 Nov 2018
    9
    Thanks Received:
    Country:
    vsmart is meant to do the heating curve automatically. but can be done manually
Loading...
Share This Page
