absolute tosh !Dont expect two long simultaneous showers though. It will run one outlet very well and usually provide limited flow in the kitchen as well.
That could reduce the heat requirent to 21 kW plus 2 kW for water and that gives 23 kW thus validating a 24 kW boiler. Tony
One advantage not often advised of the 937 store is that it produces hot water as soon as you open a tap plus the time to get to the tap of course. Non-store combis take time to warm up prior to the heated water starting to flow. The store ensures HW is available immediately.
Your calculations are correct.Please see the attached calc sheet. It gives an output of 30.3 kW, and I've not yet added the extensions which is sort of our usual hang-out area.
How thick will the B&Q insulation be? It should be a min of 250mm. On the continent they use 400mm.Its a house made in the 60 with terrible insulation, I've already paid for the B&Q 198 pound loft insulation deal, they'll get back to me sometime next week, but, the house apparently also cannot take cavity wall insulation.
We had skirting rads all round the house back in the 60s.The existing boiler I have takes an hour and a half to heat the house, and that is when I've almost turned off the radiators in 3 of the 4 bedrooms. The living room has 60s vintage skirting heating fin type things which barely get luke warm. Replace these with a couple of radiators and I'm guessing the 1.5 hour it takes to warm up will shoot up significantly.
