Does the heating come on when called for via the programmer/room stat?
If so then the problem is either motorised valve/programmer/cyl stat/overheat cutout tripped on unvented cylinder (if fitted).
No, service engineer put it into summer mode. As I have thermostat control I put it back to 70c (advised by Crofton earlier on in thread).Do you mean 'comfort mode' as opposed to 'summer mode'?
So the boiler utilises a VRT controller?
As its a system boiler only one part of the pcb works. Press button under hw symbol use + bring up to 65c press ok. Then do the same under the heating radiator symbol. It will be controlled via your clocks and stats. Leave everything else alone. Your engineer probably got confused as the 637 system boiler uses same pcb and contrrols as the 830 combis
Hey Bunny , I've not come across 'summer mode' on a 6 series boiler or 8 series boiler unless a VRT controller is fitted.
Ahhhh please listen buddy were going round in circles,,,, UNLESS YOU HAVE VAILLANT CONTROLS THE HW STAT DOES NOTHING!!! Your whole system is controlled through the ch stat... whether its hot water or heating... just turn it up an let ur external controls do their stuff
