Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Yes, but as modern veneered boards are extremely thin with the veneer layers between 0.4 and 0.8mm thick you'll need to be careful. Aluminium oxide paper at P120 or P150 grit should give a reasonable finish for further finishing.
Be sure to use a sanding block to back the paper. If you are machine sanding don't press down hard on the machine (a common error), just let the sandpaper do the work and keep the machine moving at all times. Be especially careful to support the machine near edges - there is a danger of dubbing over if you don't do this. If you stop moving the machine that's when you'll get a sand through and end-up showing the substrate
