Hi there, we have just bought a vertical radiator and the there are no instructions with it. I want to ask a question about the orientation of this radiator. It is s vertical radiator with lots of vertical bars running from top to bottom and two (slightly bigger in diameter) horizontal bars (one at each end).
If I look through the two horizontal pipes ( at the top and bottom ends), on one side, I can see through the pipe and on the other I cannot ( as I think there is a baffle). I want to know which side do the stop end and bleed valve go ( see through side or baffled side) and which side do the flow and return pipes go?
I would be grateful for clarification as I don't want to install it the wrong way around.
Thanks in advance for help.
Regards
Regards
