- Joined
- 28 Mar 2024
- Messages
- 27
- Reaction score
- 0
- Country
It is a indoor boiler in a room directly below our bedroom so I am being extra cautious. This is the thread that I saw on another part of this forum that seems to make sense.Can you remove the flexible hose from the air box, leave the door of the heatpac or the boiler house or whatever ajar and see if it runs OK for a few cycles, if a indoor boiler take more care.
"The problem you have is that a seal has failed on the balanced flue, allowing products of combustion to get sucked back into the burner causing it to constantly re-cycle taking off the front cover is allowing fresh air in to dilute the POC's present in the case you should dismantle the flue and repair the seals on the inner flue joints."
As you can see from this diagram
