    Dismiss Notice
Vinyl click flooring etc for kitchen - can anyone recommend any?
Discussion in 'Floors, Stairs and Lofts' started by Dain1, 7 Nov 2018.
  1. Dain1
    Dain1
    30 Mar 2012
    330
    Thanks Received:
    2
    Monmouthshire
    Country:
    Glued down lino is definitely not an option, hateful stuff to change.
    B&Q do click vinyl, but it only clicks properly along it's length, quite a few poor reviews too.
    Does anyone know of a good brand, maybe that uses HDF, fits together well, and won't chip if a kid drops a Tonka on it?
    Of a good serviceable and robust alternative? Maybe 18mm?
    If I could find a good one that was 18mm thk I would replace the chipboard sub with it.
    Thank you,
  2. dazlight
    dazlight
    6 Apr 2012
    1,190
    Thanks Received:
    165
    Merseyside
    Country:
    6mm Plywood then a glued down LVT floor would be best for a kitchen.
  3. Dain1
    Dain1
    30 Mar 2012
    330
    Thanks Received:
    2
    Monmouthshire
    Country:
    I don't really want Lino because I don't want glue.
  4. dazlight
    dazlight
    6 Apr 2012
    1,190
    Thanks Received:
    165
    Merseyside
    Country:
    I’m not saying Lino lol, it’s a different material.
    The best vinyl click I’ve used is quickstep Livyn.
  5. Dain1
    Dain1
    30 Mar 2012
    330
    Thanks Received:
    2
    Monmouthshire
    Country:
    I know, but you are saying glue, glue is out.
  6. dazlight
    dazlight
    6 Apr 2012
    1,190
    Thanks Received:
    165
    Merseyside
    Country:
    Livyn is a click that I’m saying.
  7. Dain1
    Dain1
    30 Mar 2012
    330
    Thanks Received:
    2
    Monmouthshire
    Country:
    I did have a look, the wear surface (or surface veneer) varies from .3 to .55 mm thk; which isn't very. That might chip quite easily.
  8. dazlight
    dazlight
    6 Apr 2012
    1,190
    Thanks Received:
    165
    Merseyside
    Country:
    Most vinyl clicks are about the same.
  9. dazlight
    dazlight
    6 Apr 2012
    1,190
    Thanks Received:
    165
    Merseyside
    Country:
    .55mm is commercial grade so you will be ok with that mate
  10. Keithmac
    Keithmac
    10 Oct 2017
    955
    Thanks Received:
    149
    Country:
    I used Quick-Step laminate in our living room and it's amazing how well it's survived, had all sorts dropped on it!.
    Even the dog hasn't managed to scratch it yet..
  11. Burnerman
    Burnerman
    7 Feb 2008
    19,184
    Thanks Received:
    3,710
    Northumberland
    Country:
    Multipanel vinyl flooring for me....the best Ive ever seen and dead easy to cut to size.
    John :)
  12. Dain1
    Dain1
    30 Mar 2012
    330
    Thanks Received:
    2
    Monmouthshire
    Country:
    Ok, I was thinking of just putting this down wall to wall, not cutting in around units etc but putting the units on top of the click flooring? What do think? Is it a good idea to put click under a washing machine?
    Thank you.
  13. Dain1
    Dain1
    30 Mar 2012
    330
    Thanks Received:
    2
    Monmouthshire
    Country:
    They have some Livyn down at the local Howdens. I didn't realise that it's vinyl to right thru, it looks good but it is quite expensive. B&Q do Click Vinyl to too, is theirs any good?
    Also, my galley kitchen 3m x 2m with a doorway in each long side, would I lay it parallel to the long sides/doorway threshold strips?
    What expansion allowance for vinyl in a room that small?
    The kitchen currently has no skirting and vinyl is flexible, can I forget about edge trim and just put skirting on afterwards? Or is edge trim always used.
    What's vinyl to like to take up later on? How might I help accommodate the various 'what if...' scenarios?
    Sub is 18mm t&g chipboard, what underlay, if any, would be best suited to vinyl click on this surface?
Loading...
Share This Page
