- Joined
- 1 Nov 2022
- Messages
- 20
- Reaction score
- 1
- Country
I am looking at installing a wall hung toilet. There is an 80mm void between the tiles and the brick wall behind. Tiles are on a plywood partition. The bricks are suitable for anchoring the steel frame, there is enough room for the soil pipe, however the 80mm void is not enough space for the cistern.
I am thinking I could fit the steel frame in the void without the cistern and put the cistern on an adjacent wall at right angles to where the toilet is. The pipe from the cistern would be about 1m long and two extra 90 degree bends, could be fitted higher than usual so can compensate for the extra pipe length with more water head.
Any comments? Will this work?
