Wall-mounted Split A/C - Planning Permission & Building Regs Questions
1 Jan 2010
Yorkshire
For years we have toyed with the idea of getting a wall-mounted a/c fitted to the bedroom and, if reasonable cost, the main living room and/or our home office. We have a portable unit with window exhaust kit but it struggles to get the room cool.
We are now about to move house so I'm thinking of installing a/c in our new property
Several questions. I'd be grateful if, when answering, you'd number your replies accordingly. Thanks!
1) I did not know that you needed planning permission to install a wall-mounted split a/c system - does it not come under permitted develpment (I am not in a conservation area and the building isn't listed)
2) Can any wall-mounted split system be DIY installed (I've heard that the units come without gas and are charged with refrigerant on-site - is this true?)
3) Does it depend on the refrigerant used as to whether you can self-install (if indeed you can)?
4) Do you require Building Regs approval - even if you don't need planning permission.
5) Who would I ask - I'm guessing my local planning department. Would they also advise on building regs?
6) There would need to be a separate electricity feed to the unit - so I'm assuming I'd need an NICEIC certificate?
7) Several internet sites recommend Daikin, Fujitsu, Mitsubishi and Panasonic units but suggest that domestic LG and Samsung units are not reliable. Would you agreee?
Finally,
8) If I can't install, is there a trade body for air conditioners that I can approach to get a "trusted" installer.
EDIT: Additional question(!)
9) If I went for wall-mounted a/c that didn't have an external unit (i.e. a self-contained monoblock unit with R290 refrigerant), could I self-install that (by running a fused spur off the ring main - something that I am allowed to do as a DIYer?). I know it would require the drilling of 3 holes hrough the wall - two large holes for the incoming and exhaust air using a core drill and a smaller hole for the condensate pipe.
Thank you.
XRD
I am watching for replies, seems crazy to me, advert everywhere for heat pumps, and then told if used for cooling different rules apply.
But it seems down to individual councils to set their own rules, but wonder if called a heat pump rather than an AC if the rules change? They are of course the same thing.
On one of our local Facebook pages a company were showing off a split system that they had installed. Someone asked them if pp was needed and they said no, as the outside unit was less than 0.6 of a cubic metre. Maybe that’s just the criteria in our area?
It seems that even asking the local council (Sheffield) if Planning Permission is required, I have to sump up £126 to be possibly told "No, you don't need Planning Permission".
XRD
XRD
Problem is that if you stick it up then your neighbours will most likely complain to the council over the noise.
XRD
Check if it falls under PD, if it does you don't need to ask. If it doesn't then you need PP.
Seems there is a problem there, @denso13 needs to read the replies first. If it were me, I would fit it, and if asked always call it a heat pump, don't call it air conditioning, and likely no one will question which direction it can work in.
