Wall Plate Height
18 Oct 2011
Yorkshire
I am building a small side extension and hopefully roofing it soon. I am trying to work out the maximum pitch I can achieve. The side of the house has windows with a brick window ledge underneath. I would like to start the flashing at the mortar line under these windows and follow across.
Building regs indicate 75mm flashing above the tiles. so basically a brick and mortar bed. Is there a rule of thumb for the spacing allowed for batons and concrete tile from the top of the wall plate, rafter joint to the underside of the flashing. I am trying to work out where i should position my wall plate to utilise as much height as possible.
All you need to do is lay, two tile batons on the ground parallel and sit a tile on top at 90 degrees,I assume that they are Marley modern or similar. Then measure from the ground to the top of the tile and this will give you the right amount of space.you can get extra pitch by cutting a bird mouth on your joist where they sit on the wall plate.Hope this helps
Thanks for the Reply Jimmy. I dont have any baton wood or roof tiles on site. I will pop to BM tomorrow and pick up a length of what i will be using and a few tiles.
Will use your approach and this should get me the measurement I need. Thanks
There are different concrete tiles!
It will be between 40 and 90mm depending on the tile. This is parallel to the rafter, so that's more vertically up the wall.
Hopefully the BM will be able to match the House roof. I will get a photo in the morning and post on here.
The side wall has three windows. I was hoping to go one brick under with the flashing. Do i need cavity tray along the full length ot the wall or can I get away with the just open wall areas?
I attach a photo showing the wall in question.
The question of cavity trays or lack of them is not a yes or no answer, especially when considering fitting them retrospectively. Exposure, wall position, shelter, wall condition, location etc can influence whether a CT would be of any benefit.
"should" is that like it "should" be ok ?
BC "should" accept it..
Take your pick
auxiliary verb
1. simple past tense of shall.
2. (used to express condition): Were he to arrive, I should be pleased.
3. must; ought (used to indicate duty, propriety, or expediency): You should not do that.
4. would (used to make a statement less direct or blunt): I should think you would apologize.
www.dictionary.com/browse/should
