Either will work, conventionally you'd do the skirting first (wallpaper paste wipes off gloss woodwork really easily, gloss paint doesn't come off wallpaper so well).
not sure why you would paper first forcing you to remove and replace the skirting every time you decorate ??
also would you rely on wallpaper paste to hold your skirting on
What will you do if there are slight gaps between the skirting and wall? It will be difficult to caulk the skirting to the paper and then paint it. You also run the risk of puncturing the paper at the junction of internal corners when you fit the skirting.
