Warm Air Heating Removal - Asbestos risk?
30 Mar 2009
I'm after some advice from the pro's / those with experience of removing a warm air central heating system.
I'm in the process of purchasing a late '60's house which has warm air heating which we will be replacing with a conventional radiator system. In what areas do we need to be cautious regarding asbestos?
I understand the boiler cupboard can sometimes be lined with asbestos and the flue could well be asbestos cement. The main question is will the ducts which deliver the warm air to each room be made of or insulated with the stuff?
The ducts are my primary concern as obviously then run throughout the entire building and I'm likely to disturb them doing other diy tasks.
I look forward to hearing your wisdom!
Parts of the boiler also might contain asbestos. Post GC Number and we can tell you.
dont really matter alan as he will have to get a licenced contractor to remove it
methinks get a survey done :idea:
theres still plenty of it in schools :eek:
Thanks. I'll take a look next time we are there. I know it is a Johnson Starley model and it was apparently only installed 8 or 9 years ago. Was asbestos banned by then?
Ducting will be metal. flue can usually be removed without breaking it and the asbestos IF any within the appliance will be on gasket material which there is no need to disturb to remove appliance
And if the compartment door has asbestos sheeting on it this can be removed along with the door in one piece or just painted over and left in place
The 'boiler' itself will be being removed by a pro anyway, along with the entire cupboard in which it lives. Hopefully any asbestos in there was replaced with supalux when the unit was replaced, but I will have a chat with whoever is going to take it out and try to make sure I get someone who takes this stuff seriously!
Good news about the ducting as I will remove the majority of this myself (where we don't just leave it in place and ignore it). Is it normally insulated atall? Should I expect it to be wrapped in anything? (Asbestos based or otherwise).
Thank you for all the help so far guys.
