Assuming U have a J&S, the Heat Exchanger flues have a bottle neck, with a Baffle (Removable from front top) these get linted and should be cleaned and vacuumed, (Flames coming out at the burner is the clue here!!
If the flue is satisfactory and the exchanger not sootted up then would you llike to explain why you think the flue will not operate and test satisfactorily?
Tony
Tony
I think its unwise that anyone advises you on gas related matters on warm air as your not quaified![]()
What goes around comes around.
As has been wisely said, continue this in the CC.
More detailed explination can be given in there and for those that dot know these units can learn something![]()
