Washing machine blowing fuse at end of program
2 Jun 2004
I have an issue with a zanussi zkg7169 washing machine.
Earlier I put a load in and it did it's wash no problems. It beeped to indicate it had finished, so I turned the dial to off and pulled my washing out.
I went back and did another load to find it was getting no power. Checked the 13A fuse in the plug and this had blown (RCD did not trip). I replaced it and all working again, so did another load. However at the end of the cycle after beeping and me turning it off it blew the fuse again.
Of course it's 6 months over its year guarantee!!!
It seems that there is no problem with the heater or the motor, but something odd about turning it off blows the fuse.
Any ideas what it could be / fault finding?
Under UK law, buyers in England and Wales can get a partial refund or full repair up to six years after the purchase was made (five years from discovery in Scotland). The refund should take into account how much use the customer has already had of a product. Ultimately, a county court would decide this.
However, the likelihood of getting such a refund is dramatically reduced after just six months. The reason is that for six months after the purchase, it is up to the retailer to show that a fault on an item is down to the actions or misuse of the buyer, rather than an inherent fault in the product.
After six months, the burden of proof switches to the buyer and it is they who must then show a fault is due to some inherent problem, something that can be almost impossible in all but the most straightforward cases.
Sounds complicated?
For example, the plasma TV you bought five months ago stops working without explanation and you return to the shop you bought it from, expecting a refund. The store manager is reluctant but can find no explanation for the fault. There are no scratches or damage to show it has been dropped, or signs of water damage. Complying with the Sales of Goods Act, he understands without such proof he must refund you money.
But were the fault to develop at seven months, he would not need such proof. The TV may show no signs of damage or misuse, but the store manager no longer needs to show there was any. Instead, you must show to him that there was a shoddy component or design fault that caused the problem. In the absence of these things, he is under no obligation to return your money.
In reality, most retailers offer returns policies that extend this 6-month period to 12 months. But after that refunds are hard to come by.
So how does the EU rule change things?
The EU directive in question is 1999/44/EC. The full wording is contained here (open the word documtent and scroll to page 7) but the important bit is this: 'A two-year guarantee applies for the sale of all consumer goods everywhere in the EU. In some countries, this may be more, and some manufacturers also choose to offer a longer warranty period.'
As with UK law, a seller is not bound by the guarantee 'if the (fault) has its origin in materials supplied by the consumer'. But the EU rule does not require the buyer to show the fault is inherent in the product and not down to their actions.
The EU rule also says buyers need to report a problem within two months of discovering it if they want to be covered under the rule.
How can I use this rule?
Reports of cases where shoppers have used the EU rule to get refunds suggest that even senior staff at stores may be unaware of it, so be prepared for some blank faces if you need to use it to argue your case. But eventually, after referring the complaint to legal teams, reports suggest the stores have coughed up.
Use this checklist to see if you could try and use the EU rule:
• The goods were purchased no longer than two years ago
• The store will not provide a refund or repair because you are returning the item after their return period has ended, usually one year
• You are reporting the fault within two months of discovering it
• The goods show no signs of damage through your actions or misuse.
The best advice is to print off the EU rule and take a copy with you. If staff fail to recognise it, ask them to take your details and report your complaint to their bosses. Take a note of the names of any staff you speak to and explain that you will contact them again soon for a response.
You may manage to get your refund on the basis of the EU directive, however, shops are within their rights to use the Sale of Goods Act as the definitive guideline instead.
What about warranties? Do I still need one?
The EU rule, while extending the guarantees for shoppers does not necessarily mean warranties have no value. Under a warranty you may get extra protection against accidental damage that would not be covered by the UK or EU regulations.
With or without the extra guarantee of the EU directive, warranties can be expensive and you should be clear about the value of any potential benefits before deciding to take one. Read our guide for help on what to look out for.
What happens when you turn it off, because that's when the fuse blows?
My first guess is door interlock releases.
It seems that when I turn it off at the end of the cycle that it when it blows.
I have run out of 13A fuses, so I need to test it to see what happens is I turn it on and off without setting it on a cycle.
If it is the door release do you know where I could source a part?
Surely if it was the door release, that would blow the fuse when it's released at the end of the cycle - or at the beginning when the door gets locked. TBH I really cannot think of anything at switch-off that could blow the fuse.
I can't either, even a damaged mains switch flashing over when switched off would be unusual, especially if it only did it on switch off and not when being switched on. It should be easy to locate though, if a fault has blown loads of fuses there will almost certainly be blast marks around the fault.
are you sure the fuses are actually blown and its just not a case of the unit resetting each time you unplug it
Pretty sure the fuse is gone as tried it in another appliance, and a continuity test on a multimeter. Both indicate blown fuse, new 13A fuse in plug (that was deemed good by continuity test) made it work again for another cycle, until I switched it off and blew
Ok, a multimeter would confirm that .
Im no expert on appliances, but is not the last thing they do, is drain the water, have you noticed any water leaking nearby.
Are you thinking blast marks on a PCB / switch?
You mention an RCD, if it is in fact on an RCD that suggests a L to N fault.
A L to N fault of a magnitiude to blow a 13 amp fuse I would expect to blow A pcb to destruction and never work again.
The house circuit it is on has a RCD at the consumer box. When the fuse blows it doesn't trip the RCD on that circuit.
Sound as though I need to open it up and look for anything out of the ordinary.
Not significant water below the washer.
To be honest I struggle to recall a plug fuse ever blowing on an rcd protected socket as most faults tend to be to earth, I would suspect something internally that Is double insulated possibly a pump or solenoid.
