Washing machine - extending hose connections
23 Feb 2007
Gloucestershire
My washing machine hose connects to an extended hose, which is turn is connected to the waste under the sink. From what I can gather, retail shops will only connect directly into a waste pipe, so won't connect a new machine. Being a lone female, will be be fairly easy to undo the travel bolts, level up machine (I can slightly lift my present one) and connect the washing machine hose to the extending one? Do I need to buy any kind a adapter/connection for the hoses?
You can do it no problem, the hose connections will be still in place from the old machine.Try disconnecting your old machine before the new one comes and you'll see how straightforward it is
Tip for moving a machine (if you dont mind having it dragged across the floor) - get down on your bum and push with your legs. :wink: Helps to have a wall behind you too! This will damage delicate floors though.
Travel bolts dead easy.
Use your old hoses, cant go wrong.
