Washing Machine Hose
18 Oct 2006
Buckinghamshire
Daughter has just bought a new Hotpoint washer dryer - model number is in flat a couple of miles away.
It came with a single connector hose which requires both hot and cold connections on the washer to be connected to the cold supply. The hose is "Y" shaped and about 1 meter from the neck of the Y to the single end.
I need one about six inches longer and thought - no problem, Plumb Centre will have them. . . . .
The man at Plumb Centre has never seen a Y shaped one before! Anyone know where I can get one? I would prefer not to have too much hose laid around in the cupboard!
I also need a four foot extension to the drain hose - are there any issues to watch for with extending the drain this much?
I thought a longer hose would be available but it is looking as if extending and putting a tee in the cold supply the cold supply would be easier!
Washer instructions say BOTH inlets to be connected to COLD supply!
Might also be easier to put a standpipe in the cupboard rather than extending the waste. Will have to look at the pipe run, annoying point is that I sealed the kick panel to the floor yesterday!
Yes - just worked that one out - thanks. For some reason I was thinking the y-piece went the other way round!
Now am I likely to have any issues extending the drain by four feet?
only in trying to join the hoses.
often seen short bit of small hose inside each grey hose, secured by jubilee clips
