Hi All, I want to move my washing machine to the utility room and put a dish washer in it's place in the kitchen.
The problem, as can hopefully be seen on the attached image, is that the waste pipe will have to run under the door frame on the side door. This has it's own issues to get it neat etc, but the more important issue is that the height of the bottom of the door is only about 100mm above the height of the drain which is about 5m away, giving a gradient of 1mm in 50mm.
My other half insists she wants it in the utility room so my question is, Is this very shallow fall for the waste pipe a problem, and if so, can anyone think of another way to sort the waste pipe issue without resorting to putting the washing machine next to the fridge?
Thanks,
Ollie
Thanks,
Ollie
