It would be nice to fit a washing machine at the far end of a kitchen as it eases the design . The problem is that the drain is 20 foot away at the window end. A 22mm plastic pipe can be run from the remote washing machine position to the drain pipe. As the washing machine pumps the drain water out I don't see a problem here. A non-return valve can be fitted in the 22m drain. The 22mm pipe would be running down all the way. A good point is that mains water could be attached to a 22mm drain and used to flush out the drain if blocked - not permanently connected of course.
Anyone see a problem here? I haven't looked at any regs yet.
thanks
thanks
