I have a separate waste outlet for a washing machine (sink outlet goes to a Grease Trap, hence its separate), the trap has had recurrence of leaks several times over the last 18 months, i have had it all apart several times, last time replacing all the rubber seals.
The leak is not a huge amount of water, more like drips, but over months its causing some issues with the floor covers, and must be fixed.
The length of pipe where the flexi is inserted is reasonably long, but I guess one comment - is the flexible outlet from the washing machine could go into a 'hose connector' with a jubilee clip to seal it - at the top there, but other than that I'm at my wits end with it.
Have I done anything wrong.
I am considering replacing it all with solvent weld, creating a U bend with it - and adding an access plug, if ever needed, I can't think of anything bad that can come of doing that
