That's the issue would they know there the cause?
Wondered if was maybe a loose jumper or something in someone's stop tap. When the water hammer starts at night it's constant. Not something that stops when you open or close a tap
Yes, could be, quite common.Wondered if was maybe a loose jumper or something in someone's stop tap.
I doesn't disappearIf you think that, then try turning a tap on in your house, see if the noise disappears.
And when pressure goes up at night it starts vibrating and doesn't stop. Someone mentioned could be air pockets in the mains can't see it as high pressureYes, could be, quite common.
Next door did mention they get a humming sound from there pressure reducing valve at night. Could be this? Or it could be humming as getting the buzzing coming down the mains from another house
I know have just swapped stuff before when trying to diagnose water hammer and then the noise has carried onLots of things could cause it, yes.
