Hi all,
I'm hoping to upgrade my incoming lead water main with 32mm MDPE in an effort to increase the water flow. However, there would be a small section, 1 metre perhaps, where I need to drop it down to 15mm copper before it splits to service cold water outlets around the house, including combi boiler. My bath and shower (shower is a tap fed combi job) isn't great, and recently got worse do to what I suspect is a fault flow restrictor in the combi, which i'll check and fix accordingly.
My thought is that this will introduce a pinch point which will pretty much reduce the flow to what it already is now, and therefore largely pointless. I'd still be on 15mm into the combi for the last 1 metre, so assuming this is a somewhat pointless exercise?
Am I right in thinking that unless the entire run can be in the larger 32mm bore, it's a waste of time? I think 25mm is the standard upgrade size, but I'll gladly oversize to 32mm for the sake a few quid (assuming 32mm MDPR > 15mm copper is possible).
I'm also thinking about introducing a water softener, so if the upgrade WAS still worthwhile despite my reservations about the 15mm pinch point, I hope that 32mm would help to mitigate any flow/pressure drop as a result of having to pass through the softener en-route.
I am assuming that I can continue to run the MDPE under the floorboards into the house until the point I want to drop to 15mm. I'm wondering if I have to drop into 15mm at the point it enters the household?
EDIT: Main Combi 30HE rated at 14.1L/min @ 30C (12.1 @35C). I'm actually getting 8L/min from bath hot tap, and 12L/min from outside tap. Could one crudely assume that by upgrading from 15mm incoming to 32mm incoming, I could expect 24L/min? Double the pipe size, double the flow rate?
Any help is much appreciated gents.
