Water Supplies in UK
14 Aug 2005
Lancashire
water question.
I know that in America they have water towers.
Do we?
To maintain flow & pressure they use water towers therefore any pumps used need only maintain enough pressure to fill the tank (Tower) at the average flow rate required rather than the flow rate that maximum demand would require.
This saves a fortune on pumps (and electric supplies to them) by using water towers for storage.
Do we do the same or do we just have pumps rated at maximum demand? I`ve never seen water towers here unless they are cleverly disguised as summat else therefore blend in.
Reservoirs up a hill is better than any pump, but we do also have towers and pumps. I used to live in the shadow of a large concrete tower.
Thanks for the reply,
yes reservoirs I have seen but many of them are below the water line of many local houses so I reasoned that they must be fed by a pump or some other storage tower perhaps
Thanks hutch too.
not noticed any around here (yet) I will have to look
There are water towers all over the UK. From the 18thC on country gentry built them disguised as follies or fake watch towers on hill tops etc.
High rise structures often situate enormous holding tanks on their roofs, similar, in a way, to the domestic CWST in many lofts.
Many ingenious "pumping" devices have been invented to get the water to the high tank in the first place. That wonderful character, Fred Dibnah, did a program on this subject.
We miss you Fred, one of the few sane people on television.
Depending on the geography of the area water supplies can often be pumped. Anglian Water's area is quite flat (especially the Fens!) so water (and sewage) has to be pumped to move it to required areas.
Some reservoirs have a river feeding them, but at certain times water is abstracted from other rivers and pumped to the reservoir to maintain levels.
Locally, then a tower (and/or underground storage reservoir) if often sited at a suitable high point to allow gravity to provide local supplies at required pressures. Some larger buildings e.g. hospitals or factories may even have their own water tower on site, either as a seperate structure or incorporated into the building. The former St Crispins hospital at Northampton had a water tank built into the clock tower, access to the clock was through a shaft within the water tank.
