Water Supply
5 Jul 2005
I had turned off the mains water supply as the washer in the main kitchen tap had completely worn and water was running unstopable. During the time the mains was off, during my absence the hot water tap in the bath was run untill the system ran empty. When I returned to the house I turned back on the water supply but still no water from the hot tap in bath and sink in upstairs bathroom, can anyone shed some light on this?
You have an air lock in the HW supply. You can clear it by forceing mains cold water up the hot tap, forceing the air out into the tank. You can do this with a hose pipe onto the hot tap oulet, or if you have a mixer tap use a strong PVC/rubber glove clamped round the spout, and open both taps, (cold needs to be high pressure) YOU MAY GET WET!
Thanks for your reply, a neighbour (plumber) came to the rescue...and I diding get wet!!!
