Waterproof furniture board. Does it exist?
1 Nov 2022
I want to make a built in bathroom cabinet that also boxes in a toilet cistern. It will be floor to ceiling so the base will get wet when the floor is cleaned.
I really don’t want to use normal furniture board. Melamine backed chipboard does not last very long in the wet conditions.
I can’t find anything suitable. Does anyone know of any suitable products?
It's a highly compressed laying of paper and resin, faced with a textured, patterned finish and the edges are a complementary colour that is polished by a progressively finder sanding. Can be cut and drilled with normal tools but I used a local water jet cutting company to do mine as the cabinet I designed was quite complex, with tabs to lock it all together
Goes by various brand names, but if you see thin worktop, circa half an inch, it will probably be this stuff. Try Googling for "thin worktop", "compact laminate worktop" or "solid compact worktop"
i used MR MDF and painted
made it a sort of shaker style - see image
on a kitchen where i had water (floor cleaning , and a couple of coffee pots which did not fill but went over the floor and behind the cabinets) caused issues with the 2 of the side panels which were chipboard expanded.
I replaced them and used a few coats of Zinsser BIN to seal in the MDF at the bottom and then painted - lasted quite a few years with no issues , before we moved house.
