I've recently moved house into an extended 4 bed semi built in the 1950s. The house currently has an ancient Ideal Mexico boiler with 11 old "radiating" radiators (rather than newer "convecting" radiators). I have been looking into changing the boiler and have obtained a few quotes to do so (currently I'm not planning to change the rads).
I have narrowed this down to a couple of options and both have recommended a Viessmann 100W boiler. However, they have offered differing advice regarding weather compensation and I am a little unsure about who to believe!
One has recommended installing weather compensation quoting the expected savings in line with the Viessmann literature, whereas the other has suggested that, whilst the boiler is compatible with the system, my radiators are not as they need to be sized correctly for the system to work properly, meaning it would be a waste of money.
My concern over the latter statement is that he didn't measure any of my radiators and he only visually looked at 3 (hall, lounge & kitchen) therefore I'm not certain how accurate his claims are.
Does anyone have experience/advice about using this system with older rads? Or is there any calculations I can do to work out if I have the right size rads?
Thanks in advance.
Thanks in advance.
