wet cavity wall installation
31 Mar 2011
Argyll
I seem to have damp cavity wall installation, when i was doing interior decoration i found the wall to very damp. i cut out a brick a was horrified to find soaking wet cavity wall insulation. my question is how do i get this stuff dried or removed or will it dry through time. i have reroofed the the property.
Have you tried a hair dryer through the air bricks?
Other than that, it will probably dry on its own
Sealed in a cavity I really don't think that insulation will dry at all unless you somehow pump a lot of air through it.
Obviously you need to fix the cause of the water ingress. was it a leaky roof ?
Thanks for the advice, i have replaced the roof so hope that has stopped any water ingress, i am thinking of taking out bricks to let air into the cavity thats all i can think of..
I seriously don't think " letting air in ' is enough. I think you need to force air through it to dry it out.
Thanks i will look into getting air into the cavity or taking the insulation out
i was never a fan of this type of insulation....
I find this puzzling. My own walls were filled with blown fibre, the fibres having been treated with a water-repellenst silicone. I swept up some of this and put it in the bin, where it got rained on. When I lifted it out of the rain-filled bin, the water just ran straight off it, the fibres were not wetted.
I reckon you have to treat it as if it was a wet wall; find the source of water, which might be penetrating rain through poor pointing, or might be water entering the cavity from a leaking roof or gutter for example; then leave the wall to dry out by the action of fresh air.
Even a wall made of lightweight concrete blocks, which can absorb a lot of water if exposed to rain during build, will dry out in a few months.
Thanks i had to replace the roof slates as they were in poor condition. when i took a handfull of the insulation from inside the wall i could squeeze water from it!! I did think maybe the gable end needs reharled i will need to look at that.
I live in an exposed coastal location, and my weather-facing wall is slate-hung. On a stormy day the water runs off it like a waterfall.
I can imagine this would wet an ordinary brick wall.
Is your wet wall badly exposed?
Yes exposed gable wall i may have to get a builder to look at the rendering on the wall. more expence, houses who needs them... i suppose thats what i get for living in Scotland , this is a rental property i own so need to get it repaired/
