What adhesive to use to fix wooden batten to wall
30 Jun 2014
Gwent
Hi all
I’m replacing my front path gate, see pic, with a new one, but sizing issues means it will need to be hung off differently located fixings which I plan on screwing into accoya blocks that are in turn pre-fixed to the wall with some kind of adhesive/bond. The gate is about the same size but pretty weighty. A quick google reveals no more nails ultra power to be the strongest external all weather adhesive, can anyone vouch for this, or if not suggest something stronger?
I'm with John. Glues are simply not designed for the sort of loading a gatepost or gate hinges gets and will fail, probably very quickly. The only way to fix this/these is to use a mechanical fixing methid instead, e.g screws and plugs, concrete screws, resin anchors, etc
OH no, please glue it.
Then next week we can answer a thread about "my gate has fallen off" :)
The original gate was fitted, badly, in the 60s, I couldn’t find any new gates of the same size where the anchor points are the same. Pity really, it would save what has been quite a tricky plan.
If it is steel it should always be possible to get a welder to grind off one (or both) of the mountings, reposition same and reweld. Bit of touch-up paint and viola! Able to reuse old mountings
