What are the rules on replacing/removing/installing an electric oven?
17 May 2013
Is this technically notifiable work that should be signed off e.g. if the sparky left the cabling in a new build could you add the oven yourself or would he be in trouble leaving the cable? Or if you get a new oven in your house are you allowed to DIY it?
Technically I'm sure it's straightforward but does the fact it's very high current mean there's special rules?
It's fine if you're in England. Maybe also in Wales and Scotland, but I can't be certain.
Wiring instructions usually come with the oven or are on a plate attached to the back so you can connect it up yourself.
However, they don't usually come with the appropriate cable attached so you will have to buy a length of the correct size based on the Kw size of the oven. You will also have to ensure your fuse/mcb is the correct rating for your particular oven.
Everything is easy when you know how..your ""high current""statement is a bit worrying.
It depends upon the oven. Both of mine came with a 13A plug fitted.
I don't see why. I'm simply asking if there are specific rules above regular 13A type stuff that most DIY-ers handle.
The ones we're looking at are more like 30A and the electrician has it on a big chunky cable running off a 32A fuse but it's an all electric cooker/hob thing. Which is why I expected it would have to be hard-wired
You asking dopy questions then fiddling with 240fekin volts!!!!
Yes, you ask 'dopy' questions when you don't know things hoping an experienced person will help out. That's the whole premise of this site
Plugging in a couple of wires is easy but why would I know the regulations off by heart if there's anything extra I need to do?
Although it's "a bit worrying" you don't know the UK runs on 230V, not 240V. Makes you seem quite "dopy" to be honest, maybe go do some reading this weekend eh? I wonder what else you don't know... I guess you're a plumber though, wouldn't expect you to know much about electrics.
I’m waiting for Mr Pedant to arrive to provide a treatise on actual UK voltages.
I think I can hear his horse trotting down the road now. Don’t worry, he won’t keep you waiting long.
but when he’s finished, just ask yourself if he has added anything to helping you with your query.
242V in 99.9% of the places I measured it.
Anyhow, I asked the op question to my electrician friend (a real electrician with qualifications and licence) and he confirmed that the oven must be connected by a "competent" person.
Then he added "competent doesn't mean registered electrician, it just means that they can follow basic electrical instructions provided by the manufacturer"
