    Dismiss Notice
Check the current amp capacity for replacing oven
Discussion in 'Electrics UK' started by Geolykos, 11 Feb 2017.
  1. Iggifer
    Iggifer
    8 Sep 2011
    4,633
    Thanks Received:
    586
    Warwickshire
    Country:
    I like the primary supply OPD being listed as a BS(EN)7671 !! With 85A rating and 0.3kA short circuit. What?!
    Somebody clearly doesn't know anything about anything. That certificate isn't worth the space it's now occupying on my HD
  2. Sponsored Links
  3. bernardgreen
    bernardgreen
    3 Nov 2006
    22,088
    Thanks Received:
    2,043
    Bedfordshire
    Country:
    Might be an idea to remove / blank out your name and address details from that certificate.
  4. Echo the husky
    Echo the husky
    25 Mar 2011
    2,476
    Thanks Received:
    326
    Devon
    Country:
    I'd also be surprised if the supply is 1phase 3wire, and limitation of discharge of energy being used as protection from shock. It even appears to have been verified by a qualified supervisor! o_O
  5. Echo the husky
    Echo the husky
    25 Mar 2011
    2,476
    Thanks Received:
    326
    Devon
    Country:
    The OPs name and address aren't on the certificate.
  6. bernardgreen
    bernardgreen
    3 Nov 2006
    22,088
    Thanks Received:
    2,043
    Bedfordshire
    Country:
    Ooopps my error
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Ah - you're missing the Schedule Of Circuits which would originally have been part of the EIC "package", and would have the details of the cable size for that circuit.
    I know - it's madness. Why they think that people don't need that information IHNI.
  8. canduit
    canduit
    1 Jul 2009
    272
    Thanks Received:
    15
    London
    Country:
    Quite recently I was looking for power rating for a Bosch double oven and an induction hob; it wasn't straight forward but found it eventually.
  9. Sponsored Links
  10. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    It can often be found, usually by looking at the installation instructions.
  11. Taylortwocities
    Taylortwocities
    28 Jul 2006
    18,711
    Thanks Received:
    1,869
    Oxfordshire
    Country:
    Indeed. The most you can get is a ( not helpful) kWh number.
    The manufacturer's website doesn't tell you the actual loadings, and the only real information is the rating plate on the appliance. You don't get to see that until it is w-a-y too lateā€¦
  12. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    If you buy a toaster or a kettle, do they only tell you how much leccy you'll use in a year assuming X slices of toast and Y cups of tea per year?
  13. Taylortwocities
    Taylortwocities
    28 Jul 2006
    18,711
    Thanks Received:
    1,869
    Oxfordshire
    Country:
    For many makers, it is only possible to find out, after an awful lot of digging.
    The NEFF energy information reveal these helpful documents EU requirement for a typical NEFF oven
    Download
    Download
    The installation instructions are less revealing, being mostly concerned with carpentry
    U14M42N5GB/01
    And the user manual even less so
    U14M42N5GB/01
    I managed to eventually find the actual load info on a john Lewis site
    http://www.johnlewis.com/neff-u14m42n5gb-built-in-double-oven-stainless-steel/p2725627
    It shouldn't be that difficult....
  14. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    But it will be until and unless people start to complain to the companies about what they are doing. I often think an effective method might be to write (using the mail, not electronic mail) to the CEO, saying that you are not complaining, but asking for assistance in understanding, and can he please help you to make contact with the appropriate person in the company who can explain to you how it helps you for the information on the actual loading to be so hard to find.
    You could follow up the inevitable failure with a polite request for an explanation of why the person who decided not to make the information readily available and who cannot show how that helps you is being allowed to deliberately do things which are not in the interests of the company's customers.
  15. Geolykos
    Geolykos
    11 Feb 2017
    10
    Thanks Received:
    Country:
    I had an electrician check it today and they said we'll have to change the board fuse to a 32A and hardwire the new oven instead of using the plug.
    However, later on I checked Currys and found the same brand as our current oven, Baumatic, (UK brand which I never considered before as I didn't know it) so we went ahead and ordered a multifunction oven with a 13A plug which runs at even lower wattage than our current one, 2.1kW, and an A+ rating. Quite surprised to be honest that Bosch ovens have an A rating while Baumatic run at a lot lower wattage and A+ rating. So I thought why not make our life easier...
    For reference, in case anyone else has similar problem, the oven is here Baumatic BOMT608X and is even cheaper on BootsKitchenAppliances with cashback and reward points.
    Thank you all for your responses.
    • Thanks Thanks x 1
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
