What could cause bulbs to 'go' frequently?
19 Nov 2006
Birmingham
Fiends of mine frequently have their light bulbs go downstairs. The light fittings are multiple-bulb type (chandelier). The bulbs go when the light is switched on. What could the causes be and how do I test?
Thanks for helping,
Alex
Relax !!! This problem does not mean you have a major wiring fault. This is a never ending problem which has been looked into for donkeys years. A wiring fault in your circuit will be picked up by fuses and MCB's long before it gets to the bulb.
There are a few reasons bulbs can blow, the major one being cheaper bulbs. The elements in cheap bulbs are much thinner and any surge of power, however slight, simply breaks them. Always go for expensive light bulbs, its cheaper in the long run.
A loose connection in the lamp holder can also cause bulbs to blow. This is because the circuit is not completed as tightly as it could be and the electricity may have cause to "arc" or jump across the contact, rather than simply flowing through it. When this happens it produces more heat in the fitting than is expected or catered for by the bulb, and the bulb can blow.
The same can happen if the spring loaded connection in the bulb holder is slightly loose. This will cause electricity to arc across the contact, cause too much heat and blow the bulb. This can very often be diagnosed by looking at the contact on the bottom of the bulb to see if it is pitted. Arcing electricity effectively melts the metal it is arcing onto ( This is how arc welding works) so if the bulb contact is being subjected to arcing, tiny little indentations occur, called pitting.
It is sometimes possible, if the live connection in your light switch is a little loos, for this to happen here also. Heat will be generated and it is possible, though very very remote, for the bulb to blow as a result of this.
When a bulb blows, 99% of the time the fuse for the lighting circuit will blow or trip also. This makes the problem seem rather bigger than it actually is. The reason for a blowing lamp tripping an MCB is that the lamp element gets thinner during its life to the point where it breaks at the thinnest point, this point will melt just before failure. The resistance of the overheating element will momentarily be very low and a current surge is caused, this is picked up by MCB's but generally not fuses.
So, three things to look into if your bulbs keep blowing. Your bulb supplier, The wire connections inside your bulb holder, and if the spring loaded connectors are working properly inside the bulb holder. As a last resort you can also check the tightness of the connections in your switch.
...Great, thanks !!!
Have you ever know a bulb go when the light are on?
I think they go when you turn them on
So leave them on & they wont go. :lol:
Lights at our shop have been left on continuously from december 05 to september 06. (staff thought they were on timer) as far as i know. quarter of all the tubes had gone. Theory disproved. :lol:
As for filament lamps though, you may be right. surges seem to take them out.
ES type fittings are more prone to loosening as opposed to the BC fitting type. This induces arcing and shortening of their life.
Also continuous switching on and off shortens the life of a lamp.
