So at the weekend I decided to get on with a job I've been meaning to do for a while. There is a single socket in our loft, spurred from a socket on the downsatirs ring in the bedroom below (you can see a slightly uneven bit of plaster where the wall was chased). I wanted a couple more sockets up there for low power stuff so the plan was to replace the single with an FCU then feed a couple of double sockets from there.
I switched off the mains at fuse box (I say fuse box because it's one of the old style wired fuse ones - although it's been retrofitted with MCBs). Pulled out the MCB labelled 'Upstairs sockets' (because I'm not risking someone else in the house switching it back on for me) and switched back on. Peculiar thing is the upstairs sockets are still live. Oh dear.
I switched off the other two 30 amp MCBs and the sockets went dead. After a bit of trial and error decided that they were being fed from another 30 amp feed that was unlabelled. So with main switch OFF I opened the front of the box and note two 2.5 mm cables in upstairs sockets and one in the other 30 amp feed - yes one 2.5mm on a 30 amp feed!
Anyway to cut a long story short, it turns out that the upstairs ring is connected to two 30 amp MCBs (one each end) and the other cable is a radial to the socket for the washing machine.
Sorted the connections out properly, swapped the MCB on the radial for 15 amps and while I was at it noted the 1.5mm cable for the outside light should be on a 6 amp MCB, not 15 amp (so I only had to buy a 6 amp one).
I know the earlier situation was A Bad Thing, but just how bad could it have been?
And I suppose you'll now tell me that I should have notified the LABC before reducing the size of the MCBs.
And yes, I think I will get a PIR in the near future.
