What dimmer do I require?
12 Jul 2008
Wiltshire
Evening All :)
Im wondering if you can help, I've bought a 5 bulb halogen ceiling light and on the box its says ''compatiably with a halogen dimmer''
My question is, what dimmer do i need? The light has a transformer in it. Any links to suitable dimmers would be really appriciated!
Many thanks
Joe
Thanks for the reply, ive fitted a low voltage dimmer but the light unit buzzes, would te dimmer above cure this?
The replacement dimmer might remove or reduce the buzzing, however the real cause of the noise is more likely to be the useless transformer in the light fitting, which is probably a circular item with the word 'eaglerise' on it.
Can I do anything about the rubbish transformer? If it helps the bulbs are 12v G4 halogen 5x 20w max.
I've fitted a mains low voltage 400w/400va.
Can I get the right type of dimmer from screwfix?
