What is causing these screw pops?
I would drill elsewhere, finding a decent place for screws to fix and then fill in old and new holes.
From the photos, it kinda looks like you have plasterboard over a moisture resistant backing (maybe).
I would expect that there is a timber stud running along the wall. I have no idea why the screws are at an angle.
I suspect that the problems are the result of the screws being buried to too deep.
Try drilling above or below the screws holes and see if you can get a decent fitting.
Standard plasterboard is 9.5+mm the backing might 18(?)mm. If so, a 50mm plasterboard screw might suffice.
I previously tried driving in a 75mm drywall screen just beneath one of the existing screws. I drove it in straight/perpendicular, not at an angle, and it never bit. There's clearly just a void directly behind these screws.
Could it be that the stud somehow sits in the corner of the wall (remember - this is a dormer) and that is why the plasterer used very long screws and driven them at an angle?
If so, I'm not quite sure what to do. I could, of course, just fill the holes and hope the screw pops don't come back! But ideally I'd like to understand the issue clearly.
I agree. You need to find the studs. You could make several things holes looking for the stud. In the corner sounds right.
You have holes to fill anyway so what's a few more if it means finding where the stud is.
Perhaps the screws are driven at an angle because there is a hard stop at some depth shorter than the screw
For example you can drive a 120mm screw at 45 degrees into a 100mm piece of wood that’s screwed to a wall, but if you try drive it in at 90 degrees, it will stop after sinking 100mm
Perhaps too there is a gap behind the wall as well as this fudgery, so the board that has been plastered isn’t actually pinched against a solid backing and will pop forever more thanks to wall vibrations (slamming a door maybe?)
Cut a section out with a multitool and show us inside the wall. Oscillating multi tool hole cuts are easy to repair if you keep the square you cut out
I think the screws have gone through plasterboard and are not doing anything.
The plasterboard is loose as not tight to wood so this pops the plaster.
Remove screws and move each one up as an inch.
Before you move them use a 10mm dill just to take top layer of plaster off. Go slow and easy, as that will help the strength of plasterboard surface when you tighten screws.
Go slow tightening screw so you don't also bust through.
Fill holes with toupret powder filler.
I doubt that will give anymore trouble.
Oh. Wood must go virtual looking at the pink mesh squares.
I think that was put up the corner to stop the mistake and popping screws but it did not work
Thanks for the considered reply. Given my lack of expertise, if I cut out a square, what is the best way to repair afterwards?
Do you think that the screws being so long and at an angle means that the plasterboard will always be slightly loose, hence the screw pops? If so, I don't see how I can resolve this, even if I move them. The screwheads will always go too deep into the plasterboard if they're at an angle, won't they?
Sorry, would you mind explaining this for me? I'm not sure what you mean by 'virtual' in this context.
What makes you think the screws are in at an angle?
Just move screws left or right if required.
Also screws should be just below surface not driven in at high speed with a impact drill.
Think that's why they are so deep.
I think you're over thinking this.
Take me 60 seconds to move screws and 2 minutes to fill holes including mixing a bit of filler...
Crack on
I think what seems to be happening (as someone else suggested earlier), that the PB isn't sat tight with the timbers, but it is sat on some insulation, allowing it to flex when pressed. Someone then leans on the panel, then the PB moves back, popping the plaster out from the screw heads.
OP - if you press on the PB, does the PB move slightly, in relation to the screw heads?
To be honest, when I push against the wall I can't see any movement. However, I suppose it only takes fractional movement over the months for the screws to pop.
Crack on
The screws are definitely at an angle. When I remove them, they are pointing in towards the corner of the wall. As I mentioned before, they are very long and only bite right at the end of their range, suggesting the timber stud is strangely placed. Also as I mentioned before, I tried driving a screw in perpendicularly and it didn't meet any timber.
Once you’ve cut eg a 10 inch square and carefully removed it you’re looking at a neat hole in the plasterboard. When replacement time comes, you find some scraps of wood (local skips can be a good source if you don’t have any lying around) - and it can be a variety, like a bit of 12mm ply or 2x1 batten or anything in between; so long as it fits inside the wall. I’ll assume you found some scrap of ply and have the means to cut it up
Cut a couple of strips of ply maybe 14 inches by 2 inches, insert them into the hole and position them at opposing edges (left right) so that you can see 10 by 1 inches of wood and the remainder of the wood is hidden by the edge of the hole. Carefully screw through the plasterboard at the top, bottom and a couple at the sides; don’t drive a screw into your finger if youre pinching everything together
At the end of this you’ll have a hole tat is now 8 by 10 inches, because of the overlaps of wood, and you can easily replace your original square, screw it in place and then filler over the edges and repaint
Drive the screws just below the surface and filler those too
This is incredibly helpful - thank you!
I don't have a multitool but could I cut out the square using a combination of drilling out corners and a Stanley knife?
I'm also wondering if putting in the batten will help with the screw pops, since presumably it will add to the plasterboard's rigidity.
I’d buy one tbh, very handy.. £32 from screwfix. But yes you can do it by hand; pick up a jab saw for less than a tenner
