What primer for Indian sandstone?
5 Dec 2012
What primer would you advise to apply to the back of the paving slabs before laying on a mortar bed?
While I’m at it, is 4:1 sharp sand:cement a good enough mix? How wet should the mortar be when laying paving?
I normally use cement and water slurry. Works well and know others who do the same. I know others who use SBR also.
4:1 sounds a bit strong. It should be only just wet enough to spread to a continuous base and level the slabs on. Too wet and it starts oozing up through the gaps when you push them down and you need to clean it up.
Cheers
So basically water and cement?
How much water per level shovel of cement?
Cement and SBR slurry. Makes for a good bond. When you lift a sunk slab, the wet muck is all stuck to the slab when you lift it.
just mix it so that it can be brushed on as a thick ish coat (think neat gloss paint ?), whether you go sbr or water
Didn’t use any primer on mine , perfectly good without .
If you’re talking about the riven multi size packs like kandla grey, raj blend etc you’ve done well. They’re very prone to not adhering
Risky. I didn't do mine at home, and a couple have delaminated off the beds. However, mine are solid wet bedded and have not disturbed the pointing. We have re-laid 'popped' patios. Not good. The first thing that gives is the pointing and the obvious rocking slab.
Correct.
We prime all our stone slabs now.....
