what should i do with this wall
21 Feb 2014
Lancashire
Im going to tile this wall the wall on the right of the image below. however i recently realised that it was way more off level than i thought, its a bit of a bodge to say the least. It actually kinks out and back in again.
my original idea was to ask a plasterer to level it out, but the more i think about it the more i think im going to have to knock off the plaster.
as the whole wall is to be tiled would you advise knocking it all off and plaster boarding the wall?
can i fix plaster board thats to be tiled with adhesive or would i need to batten in some way as im worried about losing to much more width on the room.
thanks
Above, the tall red line is level, you can see the wall kinks in and out next to it, and if you look in the window you can see the wall slopes out toward the bottom. im assuming the wall underneath wont do this? its way more obvious when you are in the room.
i may take a better picture tonight if it would be useful
