What tool for making hole bigger in old red bricks
24 Dec 2024
I'm trying to replace a old 40mm waste pipe but the new pipe is to tight in the hole so I need to knock off the brick where it's catching so is it best to buy a sds drill with chisel function or can I buy a tool that will grind down the brick with a normal drill. If you recommend me buying an sds drill can you recommend one that's not to expensive but is capable of using core drills.
How about a tile file, is it just annoying rough nibs in the hole. Or maybe buy a cheap 40mm core drill bit, very cheap may only do a couple of holes but that is all you need.
what tools do you have ?
maybe a Tungsten carbide grit Heavy Duty File, or diamond file
if you have a multi-tool maybe this sort of blade - I have used on hard brick work
i have used these
maybe a large masonry drill bit run around the inside of the hole - if you have a drill
maybe a grind wheel for a drill
Or as you say an SDS drill, whenever i used a sds drill withe a chisel bit (i have 3 types) on a Dewalt mains cable version with normal and sds chuck - to get the action to start you do need to put pressure on and that may just blow out large chunks of the brickwork
Is it is a solid brick wall (9"deep), or is it a cavity wall.
If they were red rubber bricks, they would be soft. You may have fletton bricks. They are pretty hard.
TCT core drills are much cheaper than diamond bits..
But you will need an arbor to help it interface with your drill. That is assuming that you have a drill.
Many of the products recommended thus far may, or may not be deep enough to enlarge the hole.
Be advised that trying to core drill a pre-existing hole can be difficult. Given that you are only increasing the hole by a couple of mm, you risk the bit snagging. Make sure that any drill you use has a clutch, and ideally a secondary handle.
Photos, including the current size of the hole, plus a list of the tools you have will help others advise you.
I tried with a cold chisel in the past and the bricks are to hard. Why do you think a sds drill is over the top.
A hard brick is actually easier to break with a chisel as it fractures better. Was it a sharp chisel?
A sds chisel will perform exactly the same as a hand chisel, but be harder to control. So not much good for widening a hole slightly but great for widening it massively by cracking all the bricks around the hole and slipping down the face.
But if you are just using this scenario as an excuse to buy a sparkly sds drill, I approve and will sign the note for the Mrs.
